Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
WAN Killer
danny.gullick
I have been testing the wan killer program. The only option I can get to work is to use the "echo" UDP port 7. When I try to use echo TCP port 7, I get the message "Connection forcefully rejected". Any ideas?
Also, I have noticed that when using echo udp, I would expect the transmit/receive bandwidth between the two nodes to be about the same. However, only one (in my case transmit) is reflection the wan killer settings. Ideas ?
Regards,
Danny
Find more posts tagged with
Accepted answers
All comments
Bryan
Well as far as udp goes, it is mostly associated with broadcasts which do not send back acknowledgements. This is probably why you are only showing transmit traffic.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
rharland
I've seen the same results when using echo udp (i.e., no receive traffic). I understand the nature of udp, but the ****iller manual states that you can generate a symmetric dataflow by using this setting. Apparently, that's not accurate.
thanks,
Russ
Josh_Stephens
In order to generate symetrical traffic with the WAN Killer using either TCP or UDP echos the target devices must be configured to respond to the echo requests. On a Cisco routers I believe that the commands for this are "service TCP small servers" and "service udp smalls servers". On a Windows server you have to enable and start the "Simple TCP/IP Services" services to enable the TCP echo.
HTH,
Josh
brent.king
Josh,
How can we set up WAN killer to test the throughput of a circuit? It seems that you can blast the link but there is nothing acknowledging what is being received back. We are using WAN killer to a Cisco router LAN interface with service TCP small servers and service udp smalls servers configured.
thanks,
Brent
vsop
Wan killer is just to generate the traffic, you need to use other tools to see results.
IE a packet stats on router, any qos settings you have, packet sniffers, etc. They can all be used with wan killer to test qos & bandwidth constraints.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
