Hi All,
How Solarwinds is detecting WAN UPlinks for SDWAN Aruba. Basically i need to create interface down so looking for a condition that matches these WAN uplinks dynamically.
Yes , i have raised a feature request on this
This is one of the hardest things. Usually it's either name the WAN uplinks consistently or you need to manually go into solarwinds and tag them with a custom property. I recommended having the interfaces names the same way and search for that name in your alerts/dashboards.
SolarWinds does not typically have a built-in "WAN Uplink" flag in the standard interface entities.
The WAN uplinks are usually identified based on one or more of the following:
