Are there any plans to allow the pulling of tuning data from the API. For example, the pulling information from the index advisors, query advisors and/or table advisors from the Tuning tab?
Hi @OzVegan,
Short answer: not currently.
The public DPA REST API is primarily focused on administrative and management automation (registering/licensing instances, starting/stopping monitoring, annotations, user permissions, etc.), so it doesn't currently expose endpoints to pull recommendations from the Tuning tab (Query, Table, or Index Advisors).
A couple of things to keep in mind:
Hope this helps clarify where things stand!
Okay, thank you. I'll raise a feature request. I'll look into querying the backend as a possible alternative but not going to make it a mission, I've see the schema before 😁
Hi @OzVegan , a similar question was asked in a different post. Please reference this post for additional ideas: https://thwack.solarwinds.com/discussion/152986/best-practice-for-streaming-dpa-performance-telemetry-to-elasticsearch-elk
