Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Maps and Interface Indications.
melliot1
Hi there,
We have just made the transition from HP Openview to Orion and have just come up against a little issue. We have a large switched network spread across the UK. What I am finding is that if a monitored switch interface goes down on a child/sub map this is indicated on the device icon on that child map but no indication is cascaded up to the Parent Map icon (On the Summary screen) which stays Green. If a node was to go down then this is indicated on all maps but not a specific interface. Am I going mad or have I just missed out something in the map making process. All icons are set to show child status also but I’m not sure what else to set.
All alerting is working OK but our Ops team like to see a visual indication on there map.
I have also looked on the Orion demo page and even on there it would seem that a downed interface doesn’t always show up on the main map.
Any help would be appreciated
Mark.
Find more posts tagged with
Accepted answers
All comments
BryanBecker
Mark,
In order for any interface to show up status-wise on the parent map it has to be placed on a sub map. You can't just have the node on the map.
BB
larry.rice
I'm having the same issue. I have a main map, then sub-maps for my switch fabric. The sub-map has the switch objects on that map and child status shows issues, but this does not propigate up to the parent map.
Any thoughts? Thanks
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
