Hi Team,
I want to generate the OOB reports for certain device groups which has some certain set of nodes , i don't want to use the custom property option.
How to get the data with help of device groups, any procedure or screenshots .
If you are talking about SolarWinds OOB reports and want reports for specific device groups without using Custom Properties, you can use one of these approaches: Create Dynamic Groups Create separate SolarWinds Groups based on:
Thanks @naveensingh43 , yes i have created groups but dont find the option to select the group in OOB reports
Try this to
You can also try by using the below logic
