Hi All,
I Need to create JSon API Call for a Solarwinds SWQL Query which on a Solarwinds server in SWQL Studio which can be accessed from a PowerBI Dasboard how can i create it.
Thank you Vinay i have worked and I can access the data from SolarWinds server with port 17774 with a new read-only Orion account but as you are saying i'll check with firewall team to open the port 17774 from external IP.
Please confirm any way if we can use port 443 from external server to access the API URL.
In that case you will need an account to be created on SolarWinds (easiest way is an Orion account read only) and API URL which you initially posted.
As well make sure external ip is allowed to talk to your SolarWinds servers over 17774 port, find out if there is a firewall or other placeholders where this need to be allowed through.
I have created a PowerShell script that is running and showing the output while running from Solarwinds Server However whenever am trying to access it from the outside of server from client network from where i usually access my SolarWinds but its still showing the error as "hmmm… can't reach the page." PS Script:
Import-Module SwisPowerShell
$swis = Connect-Swis
Get-SwisData $swis 'SELECT NodeID, Caption FROM Orion.Nodes'
API Token URL : https://xxxxxxxxxxx:17774/SolarWinds/InformationService/v3/Json/Query?query=SELECT%20Caption,%20NodeID%20from%20Orion.Nodes
Not Sure about the mgmt. I'll try for sql DB option
Why don't they want to give them access? Your SQL team could configure a read-only user, and probably even lock down what data / tables they have access to?
@stuartd , My mgmt is not allowing the powerBI team to directly access the Solarwinds DB
hence, they want us to use a API Call insted
I'd suggest you could start by reading the answers to your last very similar question.
Over here:
