Hi, I am trying to intigrate Boomi with SolarWinds, so that Boomi can send logs, traces etc to solarwidns to trigger an alert. how we can achive it via API? what are the ways, we are using SolarWinds HCO self hosted.
Going by the available Boomi API documentation, this should be possible to achieve if you use an API poller for: POST https://api.boomi.com/api/rest/v1/{accountId}/ExecutionRecord/query
Source: https://developer.boomi.com/docs/api/platformapi/ExecutionRecord#tag/ExecutionRecord
You can then create an Alert for the object API Poller or API Poller Monitored Value API Poller documentation: https://documentation.solarwinds.com/en/success_center/sam/content/sam-api-poller-how-it-works.htm
