Unable to log into NPM web portal.
It is throwing an exception error (SolarWinds.ApiProxyFactory. TransientApiProxy Exception
That's a generic error that could be caused by a handful of things. If the previous comments of checking/restarted SW services does not resolve it then you need to check the logs to know what triggered it (it will probably require opening a support case). The specific log in found in C:\ProgramData\SolarWinds\Logs\Orion\OrionWeb.log
Find the stack trace and post it here. That would provide the most details into what is happening.
Hi @zileyh
Reach out here in case you have more queries.
Verify all SolarWinds services are running. Try to restart them
