The node binds are not being visible in the maps. I need to know how i can make them appear in the maps and what the problem is…for more information the nodes respond to cdp , lldp and snmp well. Thanks in advance
Duplicate post:
I have responded on the other one as well.
@utande - check in SolarWinds if all interfaces are discovered and if L2&L3 topology is enabled under list resources. SolarWinds uses SNMP to collect this information and if all interfaces between the devices are discovered it will populate on maps, as well check map properties on the right hand side, I am assuming you have already checked show all connections as i can see them for other nodes.
You can as well create the missing links manually but not advised as someone needs to manage it going ahead.
Thanks @vinay.by for flagging the duplicate post
