. We are looking for support for Avamar backup failure alerts through SNMP trap resolution. please let us know anyone as done the alert configuration in solarwinds
Hi @Rameez1 -
How do you know the varbind has the value ? Do you have the raw trap message or details ?
Not sure where the issue is, but there could be several things:
The value is part of Varbind, however we are not able to populate lastActivityClient below snap for ref
If the Client ID is included in a specific Varbind (OID/Name), then you can pass on the value of the Varbind in the alert message.
Could you check the Log Viewer and identify the SNMP trap generated for the Avamar backup failure? The document below can be used as a reference for configuring the corresponding alerts in SolarWinds.
View logs and events with the Log Viewer
