HA Pool frequently flapping between Primary & Standby post upgrade to 2025.4.0 version automatically.
I have an open case on this and a cause hasn't been found
Can you all post your support case numbers? I'd like to follow these internally. Thank you!
02038947
Looks like 2025.4.1 was released 11/18/25, but I do not see a reference to this issue in the release notes. You may want to try an upgrade and see if it helps. Would be very interested in your results.
Case #:02040065
I stopped upgrading right away to new SolarWinds releases years ago. Have to wait to see how bugs are identified in a release before upgrading.
.1 HF releases are for Hotfixes, I've had much more success with those over the .0 releases. They are specific to correct issues from the .0 releases (or to correct CVEs)
It isn't resolved in a release yet. I'm still working with support. Different customers are having slightly different HA experiences across 2025.X.X versions and SW support hasn't been able to pinpoint the root cause.
Any update NV
We are still investigating. It is looking like the application is being extra sensitive to Virtual Machine configurations. The VM needs to have on demand resources to ramp up CPU and memory usage as necessary. We are also looking at things like VM snapshots, vmotion, and data backups interrupting communication to the SW application just long enough to cause a failure but not seen as a "failure" to the VM.
Smiling, I think we all eventually land here. Step up beta testers the room is yours.
