If SAP HANA performance issues are part of your world, we’ve got something new to share.
SolarWinds Database Performance Analyzer now supports SAP HANA, giving teams deeper visibility into what the database is actually waiting on when performance starts to slip. For teams supporting business-critical SAP environments, that means a faster path from “something’s wrong” to knowing where to focus.
With SolarWinds DPA for SAP HANA, you can go beyond broad monitoring and dig into the database behavior behind slowdowns. That includes wait-based analytics, blocking-chain analysis, anomaly detection, and resource metrics across SAP HANA 2.0+ and SAP HANA Cloud.
Why does that matter? Because when SAP slows down, the impact doesn’t stay technical for long. It shows up in reporting, transactions, order processing, and the everyday systems the business depends on. The faster you can isolate root cause, the faster you can get things back under control.
For existing SolarWinds customers, this is also a lower-friction way to deepen SAP HANA coverage without adding a separate specialist tool. If you’re already using SolarWinds across your environment, extending visibility into HANA is a more natural next step.
You can learn more here:
Explore SolarWinds DPA for SAP HANA
If SAP HANA is part of your environment, we’d love to hear how you’re currently troubleshooting performance issues and where deeper database visibility would make the biggest difference.
