Hi, is it possible to view Windows Event under "OSH > Alerts & Activity > Syslog" in the same way as Linux Log?
If you send the windows events to OSH, you can see them under "My dashboards" / "Logs" / "Log Viewer".
On the left hand side, filter on the type of logs you want to see.
Perfect, thank you!
