Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Threshold Indicator on Summary
DamianBunn
I have created a custom set of server lists that currently show a red indicator (dot) if a monitored node or interface is down.
Does this indicator also changed to flashing red if a threshold such as CPU or traffic is reached on a node. If not is there a way to set it.
Damian
I have just noticed the nodes with problems options under summary. I do not think I explained myself too well before. What I want to know is if using a summary of some filtered nodes, the ones with problems can be indicated in red/yellow etc.
Find more posts tagged with
Accepted answers
All comments
Isaac
Damian
Short answer is no. Long answer is still no.
You only get a color change or flashing bulb when an interface or node go down within the group. Memory, CPU, and any other threshold you may have for a particular node or interface will not change the happy colored balls.
Be fantastic
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
