Hi to everyone!
It would be great to monitor SD WAN Viptela devices using the vManage API.
These devices need to be monitored through internet, and companies, for security policies, prefer to do it using the API than with snmp v3.
Regards
Why just Cisco products? Others love Solarwinds and I understand Cisco is beloved for Switches and Routers but why limit SD-WAN to the Cisco Viptela solution?
I use SilverPeak and many others are going the same direction. Why not add SilverPeak?
Hi @bruce_jarrett
In our case we have most customers using Viptela, so for us Viptela SD Wan is a priority over SilverPeak.Of course, SilverPeak and other vendors integration are welcome.
I would like to see vManage API to be able to be alerted on within Solarwinds and more input from vManage. Would like to be able to administer vManage also within the SW platform.
This was delivered in NPM 2023.3 (initial Viptela vManage API support) and significantly extended in NPM 2025.4: full Cisco Catalyst SD-WAN (cEdge) device monitoring via the vManage API, including auto-discovery of edge devices, WAN interface monitoring, VPN tunnel visibility (status + performance), and per-interface stats. See NPM 2025.4 release notes for the full scope.
