Hi Team,
How to export the daily captured ncm backup in txt format . Because we need to send those backups to centralized NAS storage
That is what archiving is for.
Have a look at https://documentation.solarwinds.com/en/success_center/ncm/content/ncm-configuration-settings.htm?cshid=OrionNCMPHChangeArchive for more details.
Not quite sure what you're asking? If you're talking about backing up configuration archives, you should back up what is in the "Config Archive Folder Locations" to wherever you want?
You'll want to set up a windows job to actually copy them, you'll have to probably set up a service account so permissions are correct for doing this? But, it depends on how security is done on your network.
