Hi All,
We have around 2000 devices which is part of 5 different teams onboarded in same APE , how do i restrict the visibility of devices between teams.
Team A should not Team B devices.
In our organization, we use the Account Limitation, but all of our devices are assigned to teams with a Custom Property. So then the device holds the Custom Property that is used for the limitation. We have extended that to Application Owners if this is not a device but an application or Web Transaction or what ever we need.
Assign the devices to groups and restrict it that way? Group assignments can be done dynamically based on quite a few different things, make sure you look into that. The restrictions are implemented in the Users account under "Account Limitations", you should look through that to see if an easier way than creating a group might suffice? ie: if the groups are based on vendor or machine type or something you can just do that?
