I'm having a problem installing SWSH on a Windows Server 2025. Is anyone else having this problem too?
SW OSH is compatible with Windows 2025, can you be more specific?
I'm doing an installation and every time it gets stuck at this point with swis. I've already installed IIS Crypto (SolarWinds recommendation), but it didn't fix it.
Is it just stuck at that page/picture? Nothing more happening? No error messages?
You can check the log file, might give you more clues. C:\programdata\solarwinds\logs\orion\configurationwizard.log (hope I remember the path correct :-))
Or, open a ticket and they'll help you with it…
Heyyy I did the installation on SQL Express and it worked. It's a problem with the client's database, so it wouldn't have worked anyway hahahah. But thanks for the support :)
