I am unable to install solarwinds SCP/ SFTP application in my windows 2016 server. It is showing the application as incompatible. Any thoughts? /cfs-file/__key/communityserver-discussions-components-files/118/1273.unnamed.webp
This may be a Windows compatibility/elevation issue with the older SolarWinds SFTP/SCP tool rather than an SFTP issue itself. Try Run as administrator and, if needed, compatibility mode for Server 2008.
Also, the tray app and the actual SFTP service are separate, so please check whether the SolarWindsSftpServer service installed and appears in services.msc.
services.msc
Can you share:
