Hi
When I try to go to the login page for DPA on my browser, I'm getting
DPA was stopped due to the following error. DPA is attempting to restart try again in 30 seconds.
org.springframework.jdbc.BadSqlGrammarException: PreparedStatementCallback; bad SQL grammar [select V from CONPRM where P = ?]; nested exception is com.microsoft.sqlserver.jdbc.SQLServerException: Invalid object name 'CONPRM'. at org.springframework.jdbc.support.SQLErrorCodeSQLExceptionTranslator.doTranslate(SQLErrorCodeSQLExceptionTranslator.java:239) at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:70) at org.springframework.jdbc.core.JdbcTemplate.translateException(JdbcTemplate.java:1583) at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:675) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:721) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:752) at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:758) at org.springframework.jdbc.core.JdbcTemplate.queryForObject(JdbcTemplate.java:879) at org.springframework.jdbc.core.JdbcTemplate.queryForObject(JdbcTemplate.java:903) at com.confio.ignite.common.parameters.dao.ParameterDaoImpl.getParameterValue(SourceFile:276) at com.confio.ignite.common.parameters.dao.ParameterDaoImpl.getRepositoryParameterValue(SourceFile:257) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:566) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:344) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163) at org.springframework.aop.framework.adapter.ThrowsAdviceInterceptor.invoke(ThrowsAdviceInterceptor.java:113) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:241) at com.sun.proxy.$Proxy78.getRepositoryParameterValue(Unknown Source)
Any suggestions as to what this means?
