While upgrading to 2026.1.1 , successfully upgrade MPE but on APEs it showing error as below
Time to raise an incident with support - they are best placed to help with upgarde issues.
Agree with @stuartd here, check with support.
I wonder though what version you are upgrading from? And have you opened the new port that is required towards the Main poller? TCP/17734
yup ports are open, we are currently on 2025.1.1. Microsoft Identity Verification Root Certificate Authority 2020 was missing on all servers. We have installed the certificates are will reattempt the upgrade on coming Monday. Hope all goes well
If you open a support ticket, please post the number back here.
