Hello, I'm having issues where my SEM agents on my nodes aren't connecting to the manager. Any troubleshooting tips? I see the service is stopped but when i run it it automatically stops again when I refresh the services.
I still get logs from devices they are just listed as UknownInternalAgent, but they dont show up as nodes
Hi, a stopped SEM Agent service that immediately stops again usually points to one of a few common causes: connectivity on ports 37890–37892, certificate/SAN mismatch, wrong manager hostname/IP in spop.conf, or a corrupted agent certificate/store.
I would start by checking the spoplog.txt log file for any clues (C:\Windows\SysWOW64\ContegoSPOP\spoplog.txt) and connectivity towards the SEM manager on port TCP 37890-37892.
