Is there is simple way to received an alerte (email) each time a trap is received from one on my system
So, I found the "trap" variable, and it help a lot. Thank you all
Jasmin
Hey cnorborg
Thanks you for the information. Could help. With that, I'm going to continue searching.
Well, it depends on what you want in the alert. Using Variables, you can do things like have the name of the node dynamically change and have just one alert for a given trap. You can probably even have the name of the trap as a variable and stick that in there, and do one alert for all of them? However, trap names are pretty annoying, so you probably want a custom description.
So, I'd think maybe 20 alerts using variables?
thank you everyone, that was my understanding…So I have to configure Alerts for EACH traps I received for EACH node and Put a different description for the type of Alerts…that seems a log of works ?
simple maths : 20 nodes sending 20 differents traps, I have to configure 400 alerts if I want to know exactly what happened…cause creating alerts, cannot input all traps description :-)…
Thanks, Jasmin
@Lofstrand is on target, @techno-reseau when you create this make sure to create accurate conditions on which traps do you need an email alert for, traps can be too chatty at times.
Hi @techno-reseau
Yes, in Log Analyzer, create a new trap rule that triggers each time the specific traps are recieved.
On the Rule action part, choose to "send a Log Rule fired event to SolarWinds platform Alerting", check to create the new alert rule and configure the email sending action in that alert rule.
