I finally did the switch yesterday to Dark Mode and WOW. I had to fix a few maps but wow and yaaay!!
I don't think this works for classic dashboards :) , dark mode only works for Modern dashboards/widgets if I am not wrong
You are correct :-)
i love the dark mode too
lol thinking to update all my customer dashboarding to this theme, i can already see their faces :S
SolarWinds World Tour inspired dashboarding š
š® What view is that?!
What version/feature offers these dashboards?
Alert Cleared.htmlHello, I would like to share the HTML template details we have prepared so that Solarwinds alarms can become more meaningful. It can list alarm object details and connected device details separately in HTML template. Except for object and device details, you can easily add custom property informationā¦
SWQL is built on the framework of SQL and as such supports most of the standard clauses as part of a query. A very simple example query is: SELECT Caption, IPAddress, Vendor, ResponseTime FROM Orion.Nodes Dissecting this query is relatively straightforward: show some fields (Caption, IP address, Vendor, and Response Time)ā¦
Active SSL Tunnels-ASA.UnDPThis poller *should* display the number of Active SSL VPN (Anyconnect)Ā Tunnels currently connected to your box. However, I tried it with my 5520 running 8.0.4 and for some reason I get a OID Not Supported. Here's my post in the forum: *EDIT* This is confirmed working with at least Interm releaseā¦
