Hi Experts,
Need your inputs
We are planning to push/deploy Solarwinds agents on Windows servers using BigFix.
1.I had deployed APEs with HA
2.While downloading MSI & MST file from Solarwinds, it allowed to select one of the APE not VIP
3. I had selected active APE IP and created the Agent MSI & MST and shared it to BigFix team
4.BigFix team deployed agent on few servers but those servers are not reporting to Solarwinds. Command used :wait msiexec.exe /i "SolarWinds-Agent.msi" TRANSFORMS="SolarWinds-Agent.mst" /qn
5.When I checked "C:\Program Files (x86)\Solarwinds\Agent\Solarwinds.Agent.Setup" »Agent Initiated Communication" » Orion Server IP Address » It is showing "Localhost"
6. I had manually changed the IP to appropriate Active APE and manually feed the Orion User Name & Pwd , then the agent is started reporting to Solarwinds
My queries are
a. How to fix this issue, so I can automate the mass deployment of agent on remaining Windows Servers, instead fixing issue manually on each server.
b. How do I make agent to point APEs VIP instead of Individual APE
