is this UDT "Newsroom" applicable to the User/Device Tracker available in the Self-hosted SW platform or is this a separate product - and is anyone in SolarWinds able to provide any updates… there hasn't been a post since 2023!!!
No problem at all 😀
Haha - very true!
Here is an update for you! You can no longer say that the last post was from 2023, there is now a post from May 2026 entitled "Any Updates - ANYBODY????". 😁😜
@tobyw_loop1 thanks so much for the heads up on this post. I have forwarded this message on to the Tools lead and will see what I can find out.
This would be for the product in SWOSH… but maybe @Jeff_Suddarth or @John.Summers can see what's going on with lack of updates here!
