am trying to make a report for specific vlans which are on the dmz switch but the SVI is on the palo. I was able generate report for the vlans but couldnt get the IP address for those specific vlans from the palo.
it can be done if the Palo is the monitored L3 endpoint, but the IP needs to come from the Palo’s interface/L3 tables, not from the switch VLAN report, and mapping it back to the exact VLAN ID may require naming-based correlation or a custom workaround.
