:) I use to run a massive SolarWinds Ob self-hosted environment on Azure, but my SolarWinds db were Azure SQL PaaS databases. I do understand you are hesitant I was at first to, but we moved out of a DC and hosted everything on Azure. It worked like a charm.
Hi @vinay.by , I appreciate your suggestion, but my concern is about stability in Azure environment?
Hi @sandipc
I am not sure what you are looking for here, based on the questions you have mentioned. Both the options that you have mentioned are feasible.
If your question on Azure is more to do with SolarWinds performance, in case you are moving everything onto cloud, just look through the hardware requirements and build it accordingly. SolarWinds works fine on Azure provided you build your servers and database as mentioned in the pre-requisites.
We have Additional Web Server
Web poller? Do you mean a "Additional Web Server", or an "Additional Poller". I don't think there are any web servers that poll, beyond the main poller/server that is?
Either way, why move it, just create another one there? Ideally, either should be near the database and/or main poller, but not required…
I'd recommend reading this Solarwinds document on how to do this.
Deploy SolarWinds Platform products to Microsoft Azure
We're running our entire SWOSH platform in Azure and the only thing I'll say is make sure your backend SQL server(s) are very highly spec'd otherwise you will have bad latency issues. Follow the Azure SQL Server best practice and management recommendations - you want as many IOPS and as much bandwidth on the disks as you can afford. Our database disks are Premium SSD on a T20 storage tier and we still get latency.
Premium SSDv2 and Ultra disks are available and supported, and we were hoping to make use of the NVMe capability of Server 2025 in Azure but can't as yet.
