I am a beginner to Solarwinds. What is a good roadmap to learning the fundamentals? Any suggestions would be appreciated.
Providing you are a customer in active maintenance, you have access to the entire product training library through the Customer Portal. Customer Portal - Education & Training - Virtual Classrooms. Click the big green button to access our library of content. Be sure to look for the Learning Paths on the left side in the navigation filters. You will find a recommended learning path for SolarWinds Observability Self-Hosted Fundamentals.
Reach out to me if you have any further questions about finding the training you want. Also, be sure to check out each trainer's Office Hours. These are open forums with one of the Academy trainers to assist you in configuring your install for your environment. Happy learning! 😊
Take the classes, read the forums, their youtube videos are great! Play with it and learn how it works.
https://www.youtube.com/solarwindsinc
https://support.solarwinds.com/solarwinds-academy
