Hi All,
We have integrated Aruba SDN with Solarwinds however the configured speed in aruba for interface is not getting discovered in SolarWinds. It is expected beaviour ?
You don't say what the SD-Wan device is nor what version of SWI you are on. But, here's the "what" page for what 2024.2 and newer should be able to see: https://documentation.solarwinds.com/en/success_center/npm/content/npm-aruba-sdwan.htm
apologies - duplicate post
