Hi
we have migrated our SolarWinds server from another IP range but we kept the same hostname , after that we experience the error above, please advise which steps we can follow.
I suggest you open a support case on this one. I guess restarting the module engine service does not help?
There is a log file on the solarwinds server, on c:\program data\solarwinds\logs\orion and something like Businesslayer.vnqm…. check if you can get any clues in that one.
