There seems to be a limit on the number of lines that can be exported, I was wondering is there anyway you can increase it from 250k?
@LeBeauUK
You are absolutely right; you can't export more than 250K from the UI. To the best of my knowledge "NO" this is not something that can be configured and I don't believe it's there anywhere (be it on DB/Settings/Global settings).
The only 3 alternatives to this would be:
Hope this helps.
You should post this as a feature request.
If anybody else has this problem, vote up here:
https://thwack.solarwinds.com/discussion/152944/export-more-than-250-000-events-to-csv
