I have SolarWinds setup for SAML authentication. I would like to track which users are logging in, and what dashboards they are using to better gauge buy-in. Is this possible?
Thanks, Joe
Take a look at the audit log, there you should see who logs on.
What dashboard they look at is not visible. I guess you could parse the IIS log file to see that if needed.
