My old IT Kong tshirt is getting a little worn out
Starting to ask the same thing. All I can see is that there's no Monthly Mission for two months now, and thwack has not been the same for quite some time. To top it all off, it seems @Walshy who replaced @kpina as the thwack admin is no longer connected to SW. It's somewhat killing the vibe at this point.
Definitely a different vibe. It used to be a fun site to visit even if you weren't looking for technical info at the moment.
Just got off a call with our account manager he he stated that they are in process of revamping the store and to be watching for it's new launch… updated orange color and new merch being added.
I'll believe it when I see it. It has been a long time and it is definitely killing the community vibe.
