Hi Team,
I am new to SolarWinds and implementing the setup with 4k devices with two customers which kind of architecture i can choose for this implementation . I want to setup with HA with with geo
Sounds like your trying to be a "Managed Service Provider"?
https://www.solarwinds.com/partners/global-system-integrators
How the architecture should be set up depends on the requirements and the network in where it should be. But all your options are described here: https://documentation.solarwinds.com/en/success_center/orionplatform/content/orion_platform_scalability_engine_guidelines.htm
