How to optimize query if database become bottleneck
identify the slow queries,analyze their execution plans, and apply specific optimization techniques such as proper indexing, query rewriting, and effective database design
I'm guessing you're not using HCO SaaS because database analysis is built into that. For other platforms there's DPA -
Database Performance Analyzer (DPA) | SolarWinds
I have a large environment, if you are having query issues, it probably isn't on the SQL database unless the SQL server was built incorrectly.
Check out SWIS queries used on dashboards or in alerts. If they are complicated or too many joins, the app will have performance issues not related to SQL database.
If you are referencing databases in general, I agree with @fop that DPA would be a solution.
Maybe attend this class?
https://thwack.solarwinds.com/discussion/151779/tired-of-the-sql-tuning-race-let-s-talk-query-optimization-on-march-10
