Garrett Gross and I rank the top 5 best hacker movies of all time. There can be only one!
Oh Yeah! Hack The Planet!
Sneakers is probably the best of the hacking genre, although hackers was good too, but more of a coming of age movie in most sense. Unbelievable to see sneakers become reality so many years later….
