in which situation do I need use dedicated FSDB? I see in the NTA document, solarwinds recommend to use the same DB as Orion SQL DB.
ok, thanks, I got some documents stated for a separate FSDB, just confused.
You can use the same database server, although it should probably be another database. They used to require a separate server before they moved it to MSSQL. When should you get a separate one? When the SQL server is getting maxxed out, your DBA's should be able to let you know this.
