The widget is empty. In the filter all custom Properties checkboxes are selected. Any thoughts?
2025.4.0 .
YES, all problems are solved! Thank you!
What version are you running on ? Is this now resolved?
Looks like an issue, there are a few things that you can try, or best case is to raise a case with SolarWinds.
Thank you very much, sir! There was a bug when adding a node. The node was added without custom properties, even though the form contains required fields. Strange glitch. Thank you again!!!
Hi @ShoutDown
Only if the custom properties has a value assigned to them on this particular node, will they be shown on this widget.
Empty custom properties are not displayed.
