Hi Team, Could you please provide us if any SWQL to get all WLC devices and its Access points details to create the modern dashboard.
@santhoshadapa you can try below query
SELECT[WLCs].DisplayName AS ControllerName, [WLCs].ThinAPsCount AS TotalAPs, [WLCs].Status AS ControllerStatus, COUNT([DownThinAPs].ID) AS DownAPCount, ROUND((1.0 * COUNT([DownThinAPs].ID)) / [WLCs].ThinAPsCount * 100, 2) AS DownPercent FROM Orion.Wireless.Controllers AS [WLCs] INNER JOIN Orion.Wireless.AccessPoints.Thin AS [DownThinAPs] ON [WLCs].ID = [DownThinAPs].ControllerID AND [DownThinAPs].Status = 2 -- Status 2 typically means 'Down' GROUP BY [WLCs].DisplayName, [WLCs].ThinAPsCount, [WLCs].Status
