Morning!
In the Customer Portal I don't get to see our license, recent download for our product or, when clicking on Downloads, get to see any downloads at all.
Is it just me?
K
It was down yesterday due to "bigger disturbances" on the web.
It's down now?
Should be solved now! Works for me 👍️
Hope you'll get it fixed… updates waiting. Thanks.
i am also facing the same issue
We see it and are working on it….
