We use Splunk Enterprise Security and its machine learning.
Current work environment is not using it.
We're not really using this just yet
+1
Splunk and UiPath
Dell secureworks is our vendor and we are not thrilled with them at all
Not using machine learning.
using AI to do repetitive tasks.
Not at all
IDS and SIEM
I wish we were. No resource for it right now.
No, we're trying not to encourage SkyNet
nice
