Traffic information in NetPath
Visual firewall connection mapping
Traffic information in NetPath / Dynamically generated traffic map/Visual firewall connection mapping
traffic maps would be terrific, netpath is a huge bonus then the SDWan edge (single pane of glass)
interesting
Will another comment get me credit for the monthly mission?
SD-WAN VPNs in NetPath
2 - Wireless maps
3 - Dynamic traffic maps
I'm adding a fourth! Visual firewall connection mapping
I don't seem to be getting a green check mark for this even though I've completed it?
Traffic information in NetPath/ Expanded load balancer environment monitoring
traffic mapping/firewall
Visual firewall connection mapping/Dynamically generated traffic maps
Routing neighbors deletion history
#2 - Visual firewall connection mapping #3 - Traffic information in NetPath
Visual firewall connection mappingTraffic conversation deduplication
AP maps and NetPath
We have to leave a comment I think?
Firewall traffic
Netpath
SD-WAN VPNs in NetPath / firewall traffic
SD-WAN controller/edge maps and Wireless controller/AP maps
Traffic information
Netpath with traffic informatoin definitely, then dynamically generated traffic maps.
good
Wireless controller/AP maps & Dynamically generated traffic maps
SD-WAN VPNs in NetPath / Dynamically generated traffic maps
sd-wan vpns & dynamic connection maps
firewall connection mapping, traffic in netpath
Traffic information in NetPath, Dynamically generated traffic maps, Visual firewall connection mapping
firewall connection mapping, dynamically generated traffic maps
Visual NSX maps would be cool. I like the idea of visual firewall connection mapping also.
Visual firewall connection mapping and Visual NSX maps
Traffic information in NetPath, Visual firewall connection mapping
2.) Visual firewall connection mapping (3.) Dynamically generated traffic maps
2) Dynamically generated traffic maps
3) Visual firewall connection mapping
1 & 5
2. Dynamically generated traffic maps
3. Visual firewall connection mapping
Visual FW connection mapping and SD-WAN edge maps.
AP Maps, Load Balancer environment mapping
Load balancers are one of the most important parts of the services in many companies so we need more integration there to see what is happening. Visual connection mapping is important too. I like to work through with network teams to build detailed diagrams of their networks port by port so more detailed auto created dashboards for critical ports would be great.
Traffic information in NetPath and Wireless controller/AP maps
Traffic information in NetPath and Wireless Controller/AP Maps
Traffic information in NetPath and Dynamically generated traffic maps
Traffic info in NetPath, Traffic Maps, Firewall mapping.
Dynamically generated traffic maps\Traffic information in NetPath
NetFlow and network mapping created from the network device configuration (created by an external provider)
I'm a DBA so this question doesn't really apply, but you didn't give an option for that.
Firewall & Network Traffic
Dynamically generated traffic maps and Wireless controller/AP maps.
SD-WAN VPNs in NetPath Firewall traffic
Traffic information is the most important
My green check mark never stuck for some reason?
Wifi
I've commented already.
2nd - Wireless Heat Maps
This one still is not showing completed.
Wireless controller/AP maps and Visual firewall connection mapping
Visual firewall connection mapping and Dynamically generated traffic maps
1. traffic and firewall connection mapping
this question isn't registering as answered for me on the main mission page either.
nice
