Wireless APs, and Firewall
Traffic information in NetPath, Dynamically generated traffic maps, Visual firewall connection mapping
Traffic information in Netpath/ firewall connection mapping
Visual firewall connection mapping / Traffic Info in NetPath
FW Connection Mapping and SD-WAN Maps
How about cleaning up ?sound like everything is perfect ..Is the new trap/syslog app and the new maping app is 1:1 to the old ?
Plus SDWAN controller/edge maps and dynamically generated traffic maps.
Traffic information in NetPath & Visual firewall connection mapping
2. Visual firewall connection mappingExpanded load balancer environment monitoring
Dynamically generated traffic maps/Traffic information in NetPath
Firewall traffic and dynamic traffic maps
Wireless controller/AP maps
Visual firewall connection mapping/sd-wan vpns
Dynamically generated traffic maps, Expanded load balancer environment monitoring
Visual firewall connection mapping, Traffic conversation deduplication
traffic info in netpath / visual firewall
SD-WAN VPNs in NetPath
Visual NSX maps
(2)Wireless controller/AP maps and (3)Visual firewall connection mapping
Firewall traffic/mapping and traffic data across the network
Visual firewall connection mapping and Visual NSX maps.
Traffic info in NetPath, Dynamically generated traffic maps
Traffic information in NetPath / Dynamically generated traffic maps
traffic in netpath... dynamic traffic maps
Traffic information in NetPath & Dynamically generated traffic maps
Traffic information in NetPath and Visual firewall connection mapping
comment
SD-WAN Netpath and SD-WAN Maps
firewall traffic, sd-wan vpns
Dynamically generated traffic maps and Visual firewall connection mapping
Traffic info, visual firewall connection mapping
Visual firewall connection mapping, Traffic information in NetPath
Deduplication & dynamic traffic maps are my numbers 2 & 3.
Deduplication and firewall mapping.
Dynamically generated traffic maps & Wireless controller/AP maps
Traffic information in netpath
Wireless controller/ap maps
Traffic information
Dynamically generated traffic maps/ Visual firewall connection mapping
Visual firewall connection mapping and Dynamically generated traffic maps
Voted on Monday. Not showing
Dynamically generated traffic maps and Visual Firewalls
Firewall, SD-WAN, Netpath
@danielleh this question isn't registering as answered for me on the main mission page - can you reset it?
All are actually good ideas, some would be more difficult to implement
I thought I responded to this already, but I did not get a green check.
#2 Dynamically generated traffic maps#3 Expanded load balancer environment monitoring
Commenting again just in case it fixes the "no green mark" for Day 11. Also using exact phrasing for choices 2 & 3, jic.
Net Path and Firewall traffic.
Same here
1st: expanded load balancer environment monitoring
2nd: traffic conversation deduplication
3rd: visual firewall connection mapping
2) firewall connection mapping
A facility to support reporting telemetry from custom applications we are building on the network.
This question's front-end graphic says it's unanswered. But when I go in to it to answer it, it bypasses the answers, says "answered", and shows the answered stats, showing I HAVE answered it. Strange. @danielleh
Traffic information in NetPath / Expanded load balancer environment monitoring
2 - Traffic information in NetPath. 3 - Visual firewall connection mapping.
Dynamically generated traffic maps / Visual firewall connection mapping
firewall traffic, SD WANs VPNs in NetPath
yes, I have the same issue.
SD-WAN VPNs in NetPath -Wireless controller/AP maps-Expanded load balancer environment monitoring
@danielleh Can you reset the Aug 16 / Day 11 question for me? I answered it but it isn't showing a green check. Thanks!
2. Traffic information in Netpath
3. Dynamically generated traffic maps
Expanded load balancer environment monitoring and traffic information in netpath
traffic information and visual firewall connection mapping
hmm having more data added to netpath like traffic information? YES. Also the dynamic generated maps.
Visual firewall connection mapping and traffic information in Netpath would be awesome!
xxxx
Visual firewall connection mapping / Wireless controller/AP maps
Dynamically generated traffic maps/Visual firewall connection mapping
Visual firewall connection mapping and Wireless controller/AP maps
visual firewall mapping would be nice
Traffic conversation de-duplication, dynamically generated traffic maps
Dynamically generated traffic maps & Expanded load balancer environment monitoring
NetPath is invaluable, dynamic traffic maps would be awesome - especially if they are live.
Simple things like Interface bandwidth and status. NetPath services is good too. I'd love it if you could have probes down to seconds instead of minutes.
Simple things such as interface status and bandwidth are the most important to me.
Simple things like interface status and bandwidth. Routing info.
visual firewall connection mappingexpanded load balancer environment monitoring
Wireless controller/AP Maps, Visual NSX Maps, SD-WAN controller/edge Maps
2) dynamically generated traffic maps, 3) traffic infomration in netpath
2. Firewall mapping 3. Wireless controller/AP maps
SD-WAN controller/edge maps
Dynamically generated traffic maps and Traffic information in NetPath
and firewall traffic sd-wan vpns
Wireless controller/AP maps and Dynamically generated traffic maps.
Same issue here
it's the same here
Same here.
Me as well
