quote:Originally posted by Network_GuruJust tried it again using the new registry location. Still no joy HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds.Net\Orion Network Performance Monitor\SettingsREG_SZ trueOr is it case sensitive and I need to specify "True" ?I don't want to restart the polling service un-neccessarily, as it generatesfalse node down alerts when the service re-starts, which messes up our reporting.EDIT: I found the unmanage button. You need to right click and select node properties. The unmanage button is on the right hand side below the rediscover and poll now buttons!-=Cheers=- NG
quote:Originally posted by pancamoWorks! You have to right click on the node, and select Node Details. There will be a UnManage button on the right.Still testing, but so far, so good...Why is this hidden?dpHKEY_LOCAL_MACHINE/SOFTWARE/SolarWinds.Net/Orion Network Performance Monitor /SettingsAllow Unmanage REG_SZ Truequote:Originally posted by Network_GuruJust tried it again using the new registry location. Still no joy HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds.Net\Orion Network Performance Monitor\SettingsREG_SZ trueOr is it case sensitive and I need to specify "True" ?I don't want to restart the polling service un-neccessarily, as it generatesfalse node down alerts when the service re-starts, which messes up our reporting.EDIT: I found the unmanage button. You need to right click and select node properties. The unmanage button is on the right hand side below the rediscover and poll now buttons!-=Cheers=- NG
quote:Originally posted by iunderwoIt would be particularly nice to unmanage a node from the web interface, instead of on the poller...and I've been looking at how this can be done, but there is no way that I can see to get the poller to read the status if it's set from the web engine.Perhaps there needs to be a new table which the poller reads from time to time for "instructions" which can be sent from the web engine for things like unmanaging nodes.Additionally, it would be nice in the event log if it would also say when the node was unmanaged until.// Ian Underwood - Service Management// Level 3 Communications
quote:Originally posted by pancamoBesides the top 3 requests(Custom MIBS, Trap Handling and Port Monitoring) Here are some easy requests:3. Ability to automate discovery.4. Ability to import a list of devices5. Ability to place a node in Maintenance Mode for X hours6. Ability to Group Devices in the Win32 App7. Ability to Manage Nodes(add/delete/edit) from the Web8. Ability to set/override thresholds on individual nodes.
quote:Originally posted by jjohonnessIs Solar Winds working on these requests?Custom MIB importingTrap receiving and correlation
