IF YOU TAKE THIS POLL BEFORE FRIDAY JUNE 21ST OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
alright
Right..., All the above!!!!
I honestly felt the same, these weren't quite the kinds of ways I'd want to discern what I want out of monitoring.I want: - good metrics- good visibility - information accuracy- significantly better control over metric measurements, *not* ML/AI especially when it comes to linear regression (no thanks, solarwinds) - let me define the measurements I want to use! If I want metric A to be based on a delta, let me pick that as a radio button/option, more like what's done with perfstack but better please! Not "we've done linear regression for you with ML". Please no.- insightful data- controllable rollups (looking at you, intelligent maps)
Would like all. Would settle for the 1st two for now with the other to follow.
all of the above
E : ALL OF THE ABOVE. Ummmmm yeah... Gonna have to go there. I have some users that want the blinkie status lights, others want the alerts, some want troubleshooting, and now anomaly detection is the new thing.
Feels like a " You can't have one without the other" moment for me. The first three go hand in hand. Anomaly/AI abilities are quickly becoming woven into the alerting/early detection phase.
Root cause analysis is very important at our firm so we can learn and build better processes. The most important thing is detecting the issues before the end users.
I will agree all above suggestions are wonderful to have, but when it comes to the database monitoring and performance analysis there are lot of good free tools out there, I think ...deep analytics and AI to discern hidden patterns and performance issue will put SolarWinds Observability on front line.
