quote:Originally posted by mick.briggsWe monitor over 700 nodes with over 1400 monitored interfaces. We have a lot of devices taken out of service for Maintaince etc. Its a big problem when you remove a device for say one week and you have to sit there seeing it in alarm. If you delete the element then the map its attached to needs editing as when you re-add the deive to the polling engine the map does not reinstall the device, and you lose the historical data.So can we please have a feature to Pause monitoring on selected device and interfaces than delete and then addThanksMickSerco/ESA Network Services
quote:Originally posted by Janis1 To set up this feature, you will need to add the Value String of Allow Unmange to the HKEY_LOCAL_MACHINE/SOFTWARE/SolarWinds.Net/SWNetPerfMon/Settings folder. Then set the value to True and restart the Orion service. When you right-click on a node within the System Manager, there will now be an Unmanage button that will allow you to unmanage a device until a specified time and date.Janis
quote:Originally posted by iunderwoHas the Cisco Catalyst port-description thing been fixed yet? This isn't very useful:Port 3/8 · long haul fiber gigabit ethernetI know it's been asked on here before.
quote:Originally posted by Janis1There is an unsupported feature within the Orion Version 7 software that enables you to temporarily unmanage a device. To set up this feature, you will need to add the Value String of Allow Unmange to the HKEY_LOCAL_MACHINE/SOFTWARE/SolarWinds.Net/SWNetPerfMon/Settings folder. Then set the value to True and restart the Orion service. When you right-click on a node within the System Manager, there will now be an Unmanage button that will allow you to unmanage a device until a specified time and date.quote:Originally posted by mick.briggsWe monitor over 700 nodes with over 1400 monitored interfaces. We have a lot of devices taken out of service for Maintaince etc. Its a big problem when you remove a device for say one week and you have to sit there seeing it in alarm. If you delete the element then the map its attached to needs editing as when you re-add the deive to the polling engine the map does not reinstall the device, and you lose the historical data.So can we please have a feature to Pause monitoring on selected device and interfaces than delete and then addThanksMickSerco/ESA Network ServicesJanis
