quote:Originally posted by tbradleyI would love to see an On/Off switch for node/interface monitoring.ie, I'm monitoring about 1000 nodes, and around 3500 interfaces. It gets annoying, when users shut down equipment, and monitoring reports this as a down node.It would be a great help in the web interface to "administratively" discontinue monitoring
quote:Originally posted by mick.briggsWe monitor over 700 nodes with over 1400 monitored interfaces. We have a lot of devices taken out of service for Maintaince etc. Its a big problem when you remove a device for say one week and you have to sit there seeing it in alarm. If you delete the element then the map its attached to needs editing as when you re-add the deive to the polling engine the map does not reinstall the device, and you lose the historical data.So can we please have a feature to Pause monitoring on selected device and interfaces than delete and then addThanksMickSerco/ESA Network Services
quote:Originally posted by Janis1 To set up this feature, you will need to add the Value String of Allow Unmange to the HKEY_LOCAL_MACHINE/SOFTWARE/SolarWinds.Net/SWNetPerfMon/Settings folder. Then set the value to True and restart the Orion service. When you right-click on a node within the System Manager, there will now be an Unmanage button that will allow you to unmanage a device until a specified time and date.Janis
quote:Originally posted by iunderwoHas the Cisco Catalyst port-description thing been fixed yet? This isn't very useful:Port 3/8 · long haul fiber gigabit ethernetI know it's been asked on here before.
quote:Originally posted by Janis1There is an unsupported feature within the Orion Version 7 software that enables you to temporarily unmanage a device. To set up this feature, you will need to add the Value String of Allow Unmange to the HKEY_LOCAL_MACHINE/SOFTWARE/SolarWinds.Net/SWNetPerfMon/Settings folder. Then set the value to True and restart the Orion service. When you right-click on a node within the System Manager, there will now be an Unmanage button that will allow you to unmanage a device until a specified time and date.quote:Originally posted by mick.briggsWe monitor over 700 nodes with over 1400 monitored interfaces. We have a lot of devices taken out of service for Maintaince etc. Its a big problem when you remove a device for say one week and you have to sit there seeing it in alarm. If you delete the element then the map its attached to needs editing as when you re-add the deive to the polling engine the map does not reinstall the device, and you lose the historical data.So can we please have a feature to Pause monitoring on selected device and interfaces than delete and then addThanksMickSerco/ESA Network ServicesJanis
quote:Originally posted by Network_GuruJust tried it again using the new registry location. Still no joy HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds.Net\Orion Network Performance Monitor\SettingsREG_SZ trueOr is it case sensitive and I need to specify "True" ?I don't want to restart the polling service un-neccessarily, as it generatesfalse node down alerts when the service re-starts, which messes up our reporting.EDIT: I found the unmanage button. You need to right click and select node properties. The unmanage button is on the right hand side below the rediscover and poll now buttons!-=Cheers=- NG
quote:Originally posted by pancamoWorks! You have to right click on the node, and select Node Details. There will be a UnManage button on the right.Still testing, but so far, so good...Why is this hidden?dpHKEY_LOCAL_MACHINE/SOFTWARE/SolarWinds.Net/Orion Network Performance Monitor /SettingsAllow Unmanage REG_SZ Truequote:Originally posted by Network_GuruJust tried it again using the new registry location. Still no joy HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds.Net\Orion Network Performance Monitor\SettingsREG_SZ trueOr is it case sensitive and I need to specify "True" ?I don't want to restart the polling service un-neccessarily, as it generatesfalse node down alerts when the service re-starts, which messes up our reporting.EDIT: I found the unmanage button. You need to right click and select node properties. The unmanage button is on the right hand side below the rediscover and poll now buttons!-=Cheers=- NG
quote:Originally posted by iunderwoIt would be particularly nice to unmanage a node from the web interface, instead of on the poller...and I've been looking at how this can be done, but there is no way that I can see to get the poller to read the status if it's set from the web engine.Perhaps there needs to be a new table which the poller reads from time to time for "instructions" which can be sent from the web engine for things like unmanaging nodes.Additionally, it would be nice in the event log if it would also say when the node was unmanaged until.// Ian Underwood - Service Management// Level 3 Communications
For report writer to be able to send to a file.. not just email or to print.
It's been requested by your customers since 2006.. it's now 2010.. where is this feature??
