Hi Community,
When I try to edit the interface of a firewall or switch
I get the following message, Could you please advise as what could be done to resolve that ?
Really appreciate your help
Kind Regards,
Hello.
Log in / out as Admin. With lots of luck that will help.
If you can, restart all services
or reboot the server where Orion is running on. Still no good? Then initiate a repair with db ticked -> from the Windows Control Panel
1. Open Program Features
2. Select SolarWinds Orion Core Services
3. Select Repair
Best regards,
Steffen
Thanks Steffen,
It also stopped showing the dependency and the Groups information.
Reboot did the trick and solved the issue.
