nice
No, we're trying not to encourage SkyNet
I wish we were. No resource for it right now.
IDS and SIEM
Not at all
using AI to do repetitive tasks.
Not using machine learning.
Dell secureworks is our vendor and we are not thrilled with them at all
Splunk and UiPath
+1
We're not really using this just yet
Current work environment is not using it.
We use Splunk Enterprise Security and its machine learning.
